Gauges in Gauge Pod
You need to try using the side fitting connectors. They will fit at a right angle to the back of the gauge as opposed to fitting straight back.
If the pic is on your computer, go to an easy picture hosting service like http://www.tinypic.com
Click on browse to find the picture on your computer. Once that is done click on upload then copy the link in the bottom dialog box by left clicking once and then right click and choose copy. Save the link and post it in a message like this: http://i15.tinypic.com/34ffxvq.jpg
As you or anyone clicks on that link they will see the picture stored on tinypic.com. Alternately you can choose the little yellow picture icon and paste the link into the url box. Your picture will then be displayed in the message rather than having a link.
Hope this helps.
*note* these are not hooked up. so there is no wire or connector goin to them.
I believe it may be the back bolts keeping them from goin in all the way....
also Thank you for helping me put pics on here....ya'll are great.
If they feel alittle loose to ya, just put a couple little dabs of light duty glue on there. Just enough to hold it, but not too much that you cant pull it back out again. Just alittle dab'll do ya!
Justin
I dont know if it actually can cause any issues...but I tried not to get the studs too hot while cutting them. I used a dremel on my gauges in my TA...but in my Jeep I used a very fine hacksaw blade. I just wasnt sure if the vibes from the dremel would screw with the internals of the gauge.
Either way that should fix up your problem just fine!!
Justin
It will be pretty obvious what is keeping those guages from seating all the way. In my case, both my TA and my Jeep it was the studs. He's gotta check behind the pod and make sure thats whats keeping them out. But without any fittings attached its the only thing I can think of.
Justin
