OPTIMA: Yellow top or Red top???
Old Dec 8, 2006 | 12:47 AM
CULATR's Avatar
what do these covers look like??
Old Dec 8, 2006 | 04:18 AM
Blown383's Avatar
I just checked today and looks like prices went up. Red tops were $139 and yellows where $169.
-B
Old Dec 8, 2006 | 11:12 PM
WhiteStripes's Avatar
Well, red, yellow, or blue, I'm about to put a system in my car, and I'm sure they all beat out the Energizer that's in there now. I didn't even know they made car batteries.
Old Dec 9, 2006 | 12:57 AM
2001FireBird's Avatar
Question
I'm either having a problem with my yellow top or alternator. =( . Car will barely start up after 15 minutes of audio. I keep jumping it, and it'll work fine. But once I use power without the motor running, I'll know I'll need a jump afterwards. I dont know how all yours are able to keep bumpin and still be able to crank the motor.
Old Dec 9, 2006 | 07:50 AM
MyWs62FaST4u's Avatar
Most of my friends use Optima, i as well. I have a red top, but they use them BOTH! Lol!
Old Dec 9, 2006 | 04:13 PM
Blown Ta's Avatar
i just got a second yellow top, they suck
doesnt hold the charge for more then 2 days in
the cold weather.
Old Dec 14, 2006 | 04:20 PM
michaelg589's Avatar
If your car is blue and youre worried about colors. Get the blue top. It'll be overkill, but you could run the system with the car not running for a WHILE haha. But the red top SHOULD be enough for one 10 and a 400 watt amp. A friend of mine had 2 12s and a 900 watt amp with a red top. It did drain a little but not all that much. He switched to a yellow top and theres no drain. But Red should be fine for you.
Old Feb 10, 2007 | 04:52 PM
tab10's Avatar
Battery advice please, fellas... Will I need a red or yellow top...
Here is the system I have...
two eD 11Ov3s powered off of a Nine.1
eD 6500s components off of a Nine.2x
Kappa 62.7i off of the head unit.
I do travel right now quite a bit in the car, and I would need to be able to crank it on chilly winter mornings. Will a red top suffice with minimal dimming??
Old Feb 10, 2007 | 06:39 PM
6LITEREATER's Avatar
I'm sure everyone will say you will need a yellow top... I am pretty sure blue will work as well, just whatever color/price suits you best.
Old Feb 11, 2007 | 12:58 AM
Kage's Avatar
Thumbs up
Originally Posted by WS6nJAX
better safe than sorry if you like to sit around and listen to your tunes. with the added parts i would think about the yellow top as its a deep cycle battery. i have one and i cant get the thing to die. if the color yellow bothers you a battery cover may be in your future. just my opinion.
x2 True dat!!!!!!!!!!!
I have a red one w/red cover myself!!!!!!
Old Feb 11, 2007 | 07:04 AM
WhiteBird00's Avatar
Ungrounded Moderator
I am amazed that this thread has gone on for so long.
Your choice of Optima battery has nothing to do with the system you install. It has everything to do with how you use that system. The red top is a "standard" use battery - it is designed to provide the most starting power and last the longest of any battery made. The yellow top is a "deep cycle" battery - it is designed to handle repeated drainings and still recover a full charge but it doesn't have the engine cranking power of the red top.
So, if you plan to listen to your system a lot with the engine off then get the yellow top. Otherwise, get the red top.
Old Feb 11, 2007 | 09:16 AM
  #32
KEE AUDIO's Avatar
As nice as those batteries both are for your system it is overkill. If you want it becasue you just want it go for it but with that system it is not neccessary. I have a nice Bosch battery that I've been running for at least 4 years and never had an issue and I sit in my car and listen to toons all the time. My system is pulling way more amps than yours. So if your getting it because you think you NEED it you don't. But if you really just WANT it...knock yourself out...they are nice batteries. I say this because It didn't want you to waste you hard earned cash!!
Old Feb 11, 2007 | 03:01 PM
  #33
JLMoses's Avatar
I have a Red top in my car....and i must say i am disappointed in it. I am about to have to replace it again.this will be the 3rd time in the past 2 years ive had to replace it. Sometimes the car sits for a little while and the battery drains really fast. Lets see i broke my driveshaft about 3 weeks ago...so its been sittin for 3 weeks and the battery is dead. I put a trickle charger on it and it said there was "trouble" in the charging process...so i guess the battery is trash right?
Old Feb 11, 2007 | 04:41 PM
  #34
92SilverSHO's Avatar
my acdelco stocker has lasted through 2 montreal winters so far outside with the car sitting for 5 months. Im budgeting for a new battery. I have a tiny system, component fronts with tweeters and a 10inch sub with a 700watt amp. Should i get the red?
Old Feb 11, 2007 | 09:42 PM
  #35
lbls1's Avatar
Ok everyone...sorry for cutting into this thread, but here is my problem:
My car eats batteries. The car sits in the garage on average about three weeks between starts. We are having an unusually cold winter, and now my current battery (ac delco...my second battery) won't hold a charge for more than a week. I had to jump it three times in the last two weeks, and each time it died after sitting for a week (it used to go up to a bit more than 3 weeks betw. starts with no problem).
What should I do in my case? I have a powered subwoofer 100w connected with my monsoon (I defuse it when it sits.....it was really killing the battery at one time) Should I get an optima (what color) for the winter and then swap it out for a regular delco during the warm months?
Old Feb 12, 2007 | 11:28 AM
  #36
spy2520's Avatar
i must be a lucky one then, this is the second vehicle i've had with a yellow top and i've never had a problem...
Old Feb 12, 2007 | 11:33 AM
  #37
The battery is still under warranty since it's less than two years old (100% free replacement).
You need to find out what is draining the battery - they don't go dead by themselves. You've got some parasitic draw on the battery that is draining it while the car is sitting.
Old Feb 12, 2007 | 02:17 PM
  #38
JLMoses's Avatar
the only thing that i see that draws power though is the security light that flashes...and it shouldnt drain a battery....i dont thing the Amp would pull any power while the car is shut off....so i dont know of anything to pull power...
Old Feb 12, 2007 | 02:36 PM
  #39
That's why you hook up an ammeter and test - there must be something drawing power that you're not aware of or that shouldn't be drawing power with the ignition off.
Old Feb 12, 2007 | 02:41 PM
  #40
SSNISTR's Avatar
But he said it is very cold, that could kill a battery easily if it sits. When my car would sit over the winter a few weeks would drain my battery. Now I pull it out over the winter.
