power seats problem
Old Oct 28, 2006 | 10:08 PM
transambandit's Avatar
Default power seats problem
i went to install my leather seats today and the drivers side is power, the cloth seats were manual but under the seat still has the cables for hooking up the power seats and i hooked everything up but no power, so i check the wire and their is no power coming from the wire that was under the seat, is there a fuse or something i need to put in for the power seats to work? i checked the ground and it was fine, it just looks like there is no power going to the wire from the car. How do i fix this? For right now i just took the old tracks off and put them on the leather seat so i can at least has seats. But id like to get the power seat working.
Old Oct 28, 2006 | 10:14 PM
like the view?'s Avatar
check your owners manual for a fuse guide, it should also be located near the fuse box. It may be a fuse, that would be my guess. Call your local gm dealership and ask them the about the fuse.
Old Oct 29, 2006 | 12:08 AM
BLUSTREAK's Avatar
You may also check to see if your rear defroster is not working. IF not, then the 30am circuit breaker fuse has blown and you may want to try replacing with a regular 30am. That was my problem on my power seats not working on my 02
Old Oct 29, 2006 | 12:27 AM
well i just replaced the hatch to a high rise and i havent connected the defroster yet, would that not being connected factor in?
