Pics of My completed System
Old Nov 5, 2006 | 08:53 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
Default Pics of My completed System
heres the box And sub. All in all I have about 50 dollars in it ( Including wood, carpet, new blade for my jig saw, and the sub I got on clearance ) I am not looking for amazing bass, or amazing clarity. I'm just looking for a little extra humph that the stock ( non monsoon ) system just doesn't provide, even with the new head unit. I had a lot of fun building the box, thats for sure.
Heres pictures of my amp placement.
Actuall made the little flap a lot more sturdy ( weird )
Over all I am 110% satisfied with my investment. I have 50 in the sub and box, 75 in the amp, and 50 bucks in a installation kit and a few other small odds and ends ( wires, ends, ties, stuff like that ) And after messing with the gains on my amp and the head unit, I'm amazed by the improvement I have yet to listen to anything but rap * Tupacs All Eyez On Me ) and some Carcass, but Its more than enough, my only complaint would be with heavy, HEAVY double kick bass, something just doesn't seem right, but thats alright with me
Old Nov 5, 2006 | 09:01 PM
bradmb's Avatar
looks nice.
Old Nov 5, 2006 | 10:02 PM
BatmobileSS's Avatar
Do you run with your spare tire? I mounted my amp in that well and love it there.
That's a great looking sub though.
Old Nov 5, 2006 | 10:11 PM
Sgt. Spuds's Avatar
No spare tire, and I thought about mounting it there, but decided against it and went for the flap.
I couldn't find a flat area in there that would fit the amp perfectly, and felt that the amp was more protected from the elements in this position.
Old Nov 5, 2006 | 10:45 PM
todddchi's Avatar
Looks like a good budget setup. Take it with a grain of salt but your flap isn't going to last with the amp on there. They tend to bow and split under their own weight sometimes, the amp will kill it.
It's not big deal because the flaps are easy enough to pick up, just letting you know. Think of itl ike a particle board bookshelf. Sag over time, then the seams will split.
Old Nov 6, 2006 | 12:06 AM
b's90cam's Avatar
really looks good. I was thinking of making one for the passenger side. I got a sheet of mdf sitting in my garage doing nothing.
Old Nov 6, 2006 | 12:14 AM
D_Rock's Avatar
Hey thats a pretty sweet setup with the amp there. I didnt think about it until I read the post above mine about it sagging but mabey you could reenforce it with fiberglass or something.
Old Nov 6, 2006 | 12:36 AM
bradmb's Avatar
check mine out.the amp in the back seat allows the back seat to still be functional. the amp in the spare tire well is not made to look pretty. when the panel is on it looks like nothing is there.
Attached Thumbnails Pics of My completed System-amp-backseatsmall.jpg   Pics of My completed System-cerwinamptiresmall.jpg
Old Nov 6, 2006 | 07:01 AM
Sgt. Spuds's Avatar
I'm positive the flap will last, the amp isn't heavy at all.
How hot are amps supposed to get?
Old Nov 6, 2006 | 07:13 AM
01pewterbird's Avatar
should clean those wires up. run them from the side, along the inside of the flap.
Old Nov 6, 2006 | 10:12 PM
LS1Aggie09's Avatar
dang...not a bad lookin box for 50 bucks
Old Nov 6, 2006 | 10:19 PM
Sgt. Spuds's Avatar
The box itself only cost me 20 bucks including carpet to make.
Old Nov 6, 2006 | 10:30 PM
LS1Aggie09's Avatar
curious...howd you tap in to get the remote wire and rca cables?...just the adapter
Old Nov 6, 2006 | 10:39 PM
todddchi's Avatar
It's not uncommon for amps to get hot enough that you can't hold your hand on them for very long. But it should not be hot enough to actually burn you or cause any funny smells.
You have the amp mounted upside down and that is generally not a good practice. Amps are designed for the heat flow / heatsinks to work with the amp rightside up, or at least at a 90 angle. Once you start to put them upside down it's like putting a lid on a pot.
And I'm not trying to be a **** about the flap, but I'd pick up a spare if I were you. A plywood shelf seems to be sturdy but if you put 5 pounds on it for a year, it'll sag.
Old Nov 6, 2006 | 10:51 PM
bradmb's Avatar
my amp shuts off at like 165 degrees. but i do have a us amps amp. it gets hot enough to burn.
Old Nov 7, 2006 | 07:07 AM
Sgt. Spuds's Avatar
Amp isn't getting hot enough to burn me, thats a good. Thanks for teh tips, I'll consider them.
LS1Aggi09
The remote wire is running to the remote wire (blue/white)coming off my Alpine head unit ( sorry to sound sarcastic, but it is haha ) and the rca cable to the amp is coming off the pre out on the head unit.
Old Nov 7, 2006 | 09:49 AM
LS1Aggie09's Avatar
durr...sorry, i was thinkin you had the stock head unit dee dee deeee
Old Nov 7, 2006 | 02:42 PM
jimmy 2 Times's Avatar
is that box made out of plywood???
Old Nov 7, 2006 | 03:20 PM
Sgt. Spuds's Avatar
Yup, its cheap, and I had no clue what MDF was when I built it. The sound is better than what I expected, so I doubt I'll go through the trouble of making a new box anytime soon.
I knew nothing about car audio before I started this, and now I've learned a bit which I will apply towards my future projects.
Old Nov 7, 2006 | 10:33 PM
michaelg589's Avatar
well, I dont know about using plywood for a subwoofer enclosure. And, are you that cheap, that you bought fu**ing DUAL? Good god man, what were you thinking?
