Fishing new speaker wire into drivers door?
Ok, I started wiring my new system today. All was good until I got to the drivers side door. I worked on that for 2 hours and cannot get the wire fished through the door. Passenger side was a joke but the drivers side has a piece of plastic blocking access and the hood latch is in the way. I figured I would just remove the hood release but the bolts just turn so I'm guessing there are nuts that I cannot get to. Anyone know the easiest way to get new speaker cable into the drivers door?
Thanks guys. I'm no novice at this. I've probably wired about a dozen cars in my life. I have taken the entire interior out of the car covered the entire car interior in sound deadening and have run all the wires except for the main power lead (4ga wire) and the driver side door speaker wire. There is a piece of plastic covering the whole driver side area and it is behind the hood release. I cannot get that piece out and the hood release bolts (which is what is keeping this panel in) just turn. They do not come out.
So I cannot get to the inside area where the wire will come out. I can fish the wire from the door side and I can hear it hitting that plastic piece but it will not come out enough to get my hand in to grab the wire. I have yanked on the piece pulled wires out of the way, wedged my hand back there, got cut, bruised and battered and have had no luck at all. I even broke out the service manual and it does not even show that piece of **** plastic that is blocking me. It must be factory though as the harness is attached to it. If there weren't so many wires right in that area I'd cut the plastic POS out but I'm likely to cut something I don't want to cut. Oh well, I'll try again on Friday. It just really pissed me off today as I have NEVER had this much trouble running wires in a car before.
