Shift Light!!!
Old Nov 26, 2006 | 09:12 PM
camSSaro's Avatar
Default Shift Light!!!
what wire do you splice into to hook up a shift light to your rpm signal wire? I was told one of the white ones or number 28 pin. Its going in a 2000 SS
Old Nov 26, 2006 | 10:43 PM
SweeTbone's Avatar
Pin #10 right out of the lower (red) connector on the PCM. It's a white wire that will be tapped and go to the tach signal on your tach/shift light.
#28 on the Blue connector is HO2S Signal Low Bank 1 Sensor 2
and on the Red it's Ignition Control 6. STAY AWAY FROM THESE!!!
Pin #10 is the Engine Speed (Tach) Output Signal.
Old Nov 26, 2006 | 11:11 PM
02_CamaroSS's Avatar
Check this site out:
http://www.fbody.com/tech/details.cgi?id=36
It's got some pretty good install guides for much more as well.
Old Nov 27, 2006 | 12:57 PM
camSSaro's Avatar
I cant figure the damn thing out if my life depended on it. Here the deal
Spliced all there white wires correctly on the red terminal
Tried all of them to see which would work with shift light set to its lowest rpm setting
It is getting power through a fuse and is grounded properly.
The shift light comes on when the key is turned over .
I have not touched the blue side wires
ITS IS A PROFORM SHIFTLIGHT. Will these work with lsX motors? I was told it has to be on 4 cylinder mode
