Idea for Progressive Doorlock bypass?
Progressive door locks is a term used for when you hit the unlock button on the remote once to unlock the drivers door and then hit it again to unlock the passenger door.
The following instructions will allow you to unlock both locks on the first press. The second press will give you the abitlity to control anything that can be activated with a pulse.
Under the glovebox You will see a black panel that covers everything above it.
Remove the two clips right at the base of the glovebox, that hold the front side of the panel up, so that the panels hangs down giving you access to the wires above it.
There will be a green plug with five wires (Orange/Black, Red/black, Grey/Black, Tan, Grey).
Unplug the female side (light green) of the harness and cut the grey/black wire. Splice the side going back into the plug with the Tan wire.
The other wire going back into your car is now the extra channel.
Remember this wire sends a +12volt pulse, not a constant signal. Also remember to use a relay for high amperage draw applications.
The new "second channel" created by the progressive door lock mod has one big disadvantage - the pulse created by the second press of the unlock button on the remote is also generated by pressing the inside door unlock buttons. So, with the auto roll down setup, if you were driving along and accidentally hit the unlock button both your windows would go down.
the cut black/grey wire GOING TO THE CAR should splice into the tan wire. the extra channel is the left over wire GOING TO THE PLUG
also this 'green plug' is just one plug that connects to a big black module in the most uppper right section under the panel. it is not a separate male/female plug pair.
