Amp location on a 93 Firebird?
Old Dec 6, 2006 | 01:55 PM
Formula350's Avatar
Default Amp location on a 93 Firebird?
Alright, I've got a 93 Firebird Formula with the 10 spkr package. I checked under the driver and passenger side rear hatch panels, no amp. I have a Pioneer 4600MP, and everything sounds great, it's not overly quiet, the deck doesn't dim when i crank it up and its hitting hard, so I don't think it's all running off the deck. I'm just really confused. I got a Monsoon amp from a 98+ monsoon setup, and I was going to see if I could replace mine with that in hopes of maybe better sound, or if anything just know I have a replacement if somehow mine is the same.
Am I 1000% sure mines a 93? No, but if it's not then one of the previous owners swapped in a 4L60 and the whole speed density setup WITH the non-digital odometer dash. Which seems like a lot of work heh.
Did they hide it under a seat like some cars, is it behind a different panel, under the dash? I'm lost :\
Thanks.
Old Dec 6, 2006 | 05:47 PM
WhiteBird00's Avatar
Ungrounded Moderator
For the 93-94 only, the amp was mounted behind the right sail panel trim below the sail panel speakers, beside the seat and in front of the wheel well. In 95 they moved the amp to the current location in front of the spare tire.
Old Dec 6, 2006 | 10:13 PM
Formula350's Avatar
Oooohhhhhh ok, thanks. Not that getting that panel off will be easy
