Casper V-Plus Volt Booster
Old Dec 6, 2006 | 03:05 PM
My90Iroc's Avatar
Default Casper V-Plus Volt Booster
Has anyone used the Casper V-Plus Volt Booster? It's supposed to increase voltage at over 70% throttle to provide adequate voltage. I have the racetronix fuel pump and hot wire kit. Is this a worthwhile upgrade?
"Caspers
V-Plus Volt Booster
Your alternator is designed to put out a specific voltage, generally 13.8 volts. The only problem is when there's a greater demand on the electrical system, such as a WOT blast, the alternator falls a little short. The V-Plus is designed to overcome voltage taper at WOT by stepping up the alternator voltage 2.2v. at 70% throttle. Result? More power to your fuel pump and ignition system. Unit plugs in, with no wires to cut or tap into. Includes hardware. "
Old Dec 6, 2006 | 03:54 PM
Richiec77's Avatar
I've seen guys in the FI forum that love this product. It's helped with some of the Fuel issues they were having at WOT. So far, I really haven't read about anything negative about the product.
Old Dec 6, 2006 | 11:49 PM
618HAWK's Avatar
Yes it is worth while, worked well for me.
I would recomend getting the TPS wire harness extension kit that they offer as well. The only thing I did not care for was the mounting location so close to the TB. With the extensions I was able to move it to a better location, made for a cleaner install.
The reason they went with the orginal location was to prevent interferance from the Alternator. But I was sure to mount it far enough a way.
No problems, see a nice voltage increase.
Old Dec 8, 2006 | 07:56 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
3 words for you: KENNE BELL BAP.
