Ignition and Steering Wheel Column BIG TROUBLE
Car runs and drives fine, the key doesnt turn all the way so he installed a switch and a push button start. However, this means that the accessories do not work. The lights work, windows and mirrors work. Heat and wipers and radio do not. High beams are also stuck on, it appears that anything having to do with the sheering wheel controls do not work. I pulled it apart a bit and found that the switch is connected to the red wire and the pink wire. The button is also connected to the pink. I was going to connect the brown and orange wires that I see from wiring diagrams control the accessories to the switch as well., I was wondering if I do this if it will allow this to be a temp fix until I can find a steering column in my area...
I Have pictures of the mess as well if anyone wants to see.
Thanks and again NOW I'm in love with my 6 speed rocketship.
Did you need wiring diagrams, or do you already have them?
Also check your fuses at the side of the dash. Should be a 15A for the accessories you're missing. I just can't remember what fuse # it is.
I'd definately need them in front of me to help you out any. You've got a nightmare in front of you by the sounds of it. Should be able to get it to work temporarily off the switch. What kind of switch is it? Don't overload it if it's just a cheapo, and run the risk of burning stuff up...
