need help wiring up power windows
If you didn't get a power window control module you can still wire it but you won't have the express down feature on the driver's window. To eliminate the module from the connections just connect a wire from the driver's side switch terminal D directly to terminal B on the driver's motor and a wire from switch terminal E directly to terminal A on the motor.
my friend(he is an Electrical Engineer) is going to be helping me fix my window trouble over the holidays, and this is one thing he was wondering about (rather than running a wire from the battery)
thanks
There should be at least a couple of brown wires at the fuse panel. One would be the output to the power windows but another would be the power supply for the wipers. Use your tester to check for power - if it's the right wire then it won't have power until you put your fuse or circuit breaker in. The output wire you need may not be there because the car didn't come with power windows so you may have to add it yourself.
thanks
The window motor rewire is a stop-gap fix anyway. It will improve window motor performance for a while but the factory motors are not very good so they will eventually fail anyway. I put in ACI replacement motors that I got from Advance Auto. They are much faster (more like my wife's SUV) and they come with a lifetime warranty for about $60 each.
Once you're sure it's the correct wire you can either tap into it or replace it with your own wire. Unless you have a convertible it doesn't do anything except power the windows.
If it turns out that the power and ground are okay I can give you a series of diagnostic tests to run at the switches to find the problem.
