compent and full range speakers?
Old Dec 18, 2006 | 04:29 PM
king_kong's Avatar
Default compent and full range speakers?
whats the differnce betwean componet and full range speakers like are the componets louder or somthin what?
Old Dec 18, 2006 | 05:03 PM
WhiteStripes's Avatar
If by full range you mean coaxial, then the difference is that the highs and lows are an all in one package it's one speaker with a built in woofer, and tweeter. The components use a seperate tweeter that mounts in a different location from the woofer. Generally yes, you get better sound out of component speakers.
Old Dec 19, 2006 | 10:38 AM
lo_jack's Avatar
Components allow each piece (tweeter, woofer, sub) to specialize in one set of frequencies, so they can do what they are good at and leave the rest to another piece. It makes them have to work less hard to produce the frequencies they are desinged for, so they are more efficient.
So just like people get a sub for boom, you also get tweeters for highs and woofers or mids for mid range frequencies. Each gets only the frequencies it was designed for, not other ones it cannot make.
You go to a steakhouse for steak, you go to Whataburger for burgers (and chicken biscuits). Not the other way around or one for both.
A coax speaker is a compromise. Put all frequencies into one unit and do all of them decently, but excel in none. Like TGI Fridays. Exception is any coax that has a crossover with it, like Infinity Kappas. Their coaxes started coming with crossovers a while back, and the function more like a component and less like a coax, so they say.
This says nothing of soundstage and space matching. Being able to move the tweeters away from the woofers is an advantage of its own. That is an entirely different discussion.
