Mounting amp in hatch
Old Dec 19, 2006 | 04:56 PM
jlarsen's Avatar
Default Mounting amp in hatch
I'm finally mounting my amps in the bird and want to do so on the hump behind the rear seats above the gas tank since my box will sit in the recess. I'm a bit worried about my screws going too far, so what have all of you done or seen to avoid drilling in too far?
I'm thinking about putting down some aluminum strips across the top under the carpet to drill down into, anyone tried this approach?
Old Dec 19, 2006 | 11:03 PM
firebirdman469's Avatar
I actually found out that the capret itself has some slack in it. I ended up cutting a piece of treated particle board just big enough to fit under the carpet, and driolled into that. I believe the piece was about 1/4" thick. Hope that might help you out.
Old Dec 20, 2006 | 12:23 AM
69z-28's Avatar
yep. i actually took a long peice of 3/4" MDF that i had left over from my actual sub box and i laid that as far up as i could against the backseat under that carpet, then scred by sub box to that with some L brackets right through the carpet. worked AWESOMELY. it was mounted so well for just going through the carpet, i was shocked. and it gave an awesome clean look with no mounting points shown. i did it for my box, but same thing for an amp.
Old Dec 20, 2006 | 01:35 AM
jlarsen's Avatar
Well I went ahead and went with my first idea, grabbed some aluminum strips and jb welded them across where my amps will be mounted, it worked much better than I thought, this raised it a little over 1/4" and I'll still keep the padding over it. Here's a quick picture, i'll snap another one tomorrow with everything in once I get it cleaned up.
Old Feb 8, 2007 | 09:17 AM
dirtyblackhoe's Avatar
anymore pics of any of these setups guys?
