yellow top opyimas
Optima D35 Yellowtop Battery
# Voltage: 12v
# Minimum Weight: 36.4 lbs.
# Cold Cranking Amps: 32°F 810, 0° 650
# Length X Width X Height: 9.31 X 6.81 X 7.63"
# Capacity Ampere Hours @ 20 Hr Rate: 48
# Reserve Capacity: 98
# Internal Resistance (ohms): .0030
# Post Type: SAE Post
im in the market for a battery
was thinking for about $35 bucks more i can get a badass battery, beter than wal mart and auto zone and them stores
should i get it? or its not really needed? save myself the 35 bucks?
For normal purposes, they're extremely overrated.
I believe the yellow also has fewer CCAs and WCAs, but it's been a while since I looked at Optimas.
that and they last forever. I know I had one for 5+ years in one of my last cars
The yellows are good if you plan to run them down, but they have a short 1 year free replacement.
The reds are good for everyday use where you don't plan to run them way down. They are cheaper and have a 3 year free replacement.
I have a CarPC as well and the dang Opus 150 is designed to maintain standby power which is good if you use Standby, but pulls excess power and will kill a battery in like 6 months. I'm going to swap it out or mod it and then pop in a new red top under warranty.
I actually plan to run 2 new red tops in parallel to handle my new sound system.
Yellow tops are designed for just this purpose. Using a redtop with any sort of aftermarket gear actually voids it's warranty.
mike
I see no reason why the reds would not be good for stereos. So far it has proven to be excellent. I also don't plan to run them down or deep cycle them or be in a competition (engine off) or anything like that. That would be better suited to the yellows.
PS. If the store asks if I run them on a big sound system or a winch, I'll simply say no.
bottom line, is if you want to play your system with the engine off, go with yellow.
I've been using yellows as my starting battery with no issues, I see absolutely no reason to use a red top unless you were building a race car and wanted a gel cel battery in the trunk.
I have no intention of "running them down" or even listening with the engine off. (well, maybe for no more than 2 minutes or so).
The reason I want 2 bats is to supply enough current to the amps to keep the voltage from dipping. I'll have 2100w of class A/B amps to feed. Maybe more depending on how many more amps I'll add.
I want the dual batteries and the 235 amp alternator to try and keep the voltage really high on transients. As the voltage gets lower, so does the amps power.
Anyone have any thoughts on this?
which is why I was confused as to why you wanted parallel batteries with no intention of extended engine off play.
In a big SPL rig, even the biggest alternators out there are not going to power your system. You are going to be running off of batteries no matter what. Which is why some guys use 16 volt batteries.
But for your listenable street system, batteries are for handling engine off play. For what you want, only solution is the biggest, beefiest alternator you can find.
I never ever heard of a 1 battery per thousand watts rule, only the marketing driven 1 farad cap per thousand watts.
mike
Anyway, no big deal. One less part to buy. And yes, if I were the type to play it a lot with the engine off, I would get dual Yellow tops.
It would be nice if someone made 14v batteries.
I'm actually thinking of getting the alternator with a set 14.7v regulator. The amperage will of course vary with load just like a stock alternator, but the voltage would stay high. I need to look into that so I'll save it for another thread.
