power wire ?
Old Jan 16, 2007 | 05:27 PM
99midnightZ's Avatar
Default power wire ?
ok im getting rdy to install my subs in my camaro and i have read alot about being able run the power wire through the firewall gromet under the computer.....this is fine and i dont have a problem doing it i just cant figure out how to get the computer out so i can find the gromet....i took the bolts out holding it in and tried that way...took the connectors of the pc and tried slidding them out and i cant seem to get them out...any help would be awesome!
Old Jan 16, 2007 | 06:46 PM
fredmr39's Avatar
hmm....are you sure you got both bolts? I've never heard of this problem before...
sorry that wasn't much help, not sure what else to say..should only have to remove the two 10mm bolts, don't even have to disconnect any connectors..
Old Jan 16, 2007 | 07:17 PM
yea i took both bolts out and it seemed like i couldnt pull the entire cluster out....it keep hitting part of the fender mount..(where its like welded)....
i might have to just pull my skirt up alittle bit and pull like a man...lol hahahaha
Old Jan 16, 2007 | 07:48 PM
fredmr39's Avatar
the space is pretty tight -- be sure not to hurt and paint....remember: just wiggle and pull....maybe put more emphasis on the wiggling (but of course don't forget to pull too!)
Old Jan 16, 2007 | 08:10 PM
lol... i will try again tomarrow when its not 9 dergress out...lol
