Quick Amp/Sub RMS question...
Old Jan 17, 2007 | 08:15 PM
Silas2k's Avatar
Default Quick Amp/Sub RMS question...
im looking at a sub that has:
Peak Power Handling 600 watts approx.
RMS Power Handling 300 watts
do i need an amp with 600w rms or will 300 do? or maybe 4-500?
Old Jan 18, 2007 | 12:44 AM
Armyman2445's Avatar
personally i would match the RMS levels from sub to amp. If your putting 2 300w RMS subs then i would go with a 600w RMS amp. if only one 300w RMS sub then an amp that is 300w RMS. You can add a bigger amp but then it will take away some of the life from the sub
Old Jan 18, 2007 | 03:34 PM
Silas2k's Avatar
so i shouldnt look at the peak rms of the sub when picking the amp? so if i get that one with 300rms, and 600 at peak... i should still get a 300rms amp?
thx
Old Jan 18, 2007 | 05:46 PM
fredmr39's Avatar
thx
correct...(generally)
also, "peak rms" is contradictory... peak power was the term you were looking for.
Old Jan 19, 2007 | 11:43 AM
FireBird_Fr3ak's Avatar
IMO never look at any peak specs...
Old Jan 19, 2007 | 11:53 AM
fredmr39's Avatar
I agree in general. I WOULD however still look at them, just don't pay attention to them. I have seen discount sites that have peak AND rms powers the SAME.... so which one is right? you don't know...since it was a simple error in typing or someone decided that RMS power was the peak divided by n-channels, or whatever (or they could simply multiply RMS values for peak for some reason). I ended up checking at another site because I was curious, and it turned out that the peak power was correct...meaning the actual continuous power ratings were much lower than advertised.
Old Jan 20, 2007 | 10:24 AM
jak2908's Avatar
when i got my 15" Kicker L7..its rated at 1000w rms and 2000peak i think? and so i bought a 1600w rms amp..giving it all clean power..not dirty..something you would do with a low powered amp..turn the gain up and all that crap..makes the signal dirty..so with my amp i got it all turned down and i dont have to worry about breakin a thing because my subs gettin clean power...thats what really matters IMO
