Blown Fuse
Old Jan 21, 2007 | 03:59 PM
99LS1Ws6's Avatar
Default Blown Fuse
I keep blowing the same fuse. Its a 10 amp fuse. The same thing happens every time. I change the fuse, I'll start driving then my gauges will go out. I can continue to drive, but once I turn my car off, it won't start up the next time. I have taken it to a mechanic has he pulled up the wiring diagram and he can't seem to find the problem. Any suggestions?
Old Jan 21, 2007 | 04:08 PM
fredmr39's Avatar
What circuit?
Old Jan 21, 2007 | 04:28 PM
99LS1Ws6's Avatar
Not sure my car is still at the shop. The fuse is in the cab inside the door jam at that panel. Inside the box its on the far left side in the middle. If I can remember right its one of the only 10 amp fuses in there.
Old Jan 21, 2007 | 05:06 PM
2001NBMZ28's Avatar
Sounds like the GAUGES #9 fuse. BCM, brake-trans shift interlock, panel cluster, DRL module are all on that circuit. Can they read BCM codes?
