recommendations on amp...
Old Jan 22, 2007 | 09:32 PM
TruDualed95Z's Avatar
Default recommendations on amp...
im looking for a decent amp to push one 10" L5 solobaric sub in a subthump box. any recommendations?
Old Jan 22, 2007 | 09:51 PM
RedRallyeZ's Avatar
dual 2 or 4 ohms?
Old Jan 22, 2007 | 09:52 PM
2 ohm
Old Jan 23, 2007 | 05:46 PM
RedRallyeZ's Avatar
i say this one: click me I have one from that lineup and I am pleased with it. Great price and it comes with a pretty cool remote too.
Old Jan 23, 2007 | 07:23 PM
fredmr39's Avatar
awesome amp - I remember one of the Kenwood's being stable @ 1 ohm....but can't remember which. Also - did you purchase the sub already? If not and if you do go with that amp, you may want to go with the dual 4 ohm voice coils so that you don't have to have the gains as high....you'll have a a lot more excess power, but at least you'll be sure you're getting the cleanest signal possible from your amp.
Old Jan 23, 2007 | 10:45 PM
RedRallyeZ's Avatar
Its the 9152D, the one ive got, there may be others but i know for sure that one is. That KAC series hits hard, they are inexpensive and they look great. I have a 8452 4 channel and that 9152 mono from that exact lineup
Old Jan 24, 2007 | 12:12 AM
fredmr39's Avatar
sweet - thanks for the info!
Old Jan 24, 2007 | 12:37 AM
thanks for the help. i havent purchased the sub yet but ill check into the 4 ohm.
Old Jan 24, 2007 | 12:44 AM
I also currently have the stock monsoon system in the car and am pretty happy with it. Would this sub work okay off the stock hu (I know an aftermarket hu would probably work better, but if I can get by with decent bass with the stock one i will)
Old Jan 24, 2007 | 09:05 PM
RedRallyeZ's Avatar
you will probably have to get an aftermarket wiring harness thing that allows the use of RCA's to the headunit. A stock HU doesnt havethe RCA's, but the harness isnt that expensive. just go by best buy and pick on up for around $15. scosche makes them
And you siad youll look up the 4ohm? the recomendation i made for you was for the dvc 2 ohm woofer, if you go 4 ohms youll cut the power in half, not a huge deal but you might want to shop around a little more if you go for a four ohm woofer
