Just finished building a TANK! ! !
Sealed the inside with glue IN the joints, caulking in the seams, double layer of fiberglass & some cases triple layer. Then filled minor cracks outside with plastic (mix that hardens).
Soldered the wires inside w/the quickconnect box outside. Filled the space with cotton batten. Then also covered the outside face with actual trunk material from a Camaro. Just need to find a grille to protect the speaker.
Speaker/Subwoofer is designed for a 1.5 cu ft enclosure. This one works out to 1.4 (1.38 cu ft). Hope I don't hear the difference.
Thoughts?
assuming that's a 10" sub, that box looks no where near 1.4 cu ft.
about the best people have gotten in the driver side without fiberglass is .6 or so.
Sorry for the mispost!
