Help with Raptor install
Installed on a 2000 Camaro SS M6. Green wire tapped into the #10 pin on the lower pcm. Red wire tapped into the pink wire on the ASR. Ground to screw under glove box (same as stated on InstallUniversity). Started to car up... and nothing. No flashing, nothing. I checked to make sure I had it on the right cylinder mode for the LS1 (4 cyl mode, down, up, down), and I had it set the opposite (up, down, up) so I switched it.
Started the car back up, and again, nothing.
I'm guessing that for whatever reason, the shift light isn't getting power. the wire taps I bought were for 18-22 gauge wire, and I ran 20 gauge wire from the wire taps to the shift light, connecting them with snap-locks. Is it possible that the taps aren't making a good contact? Should I find a better ground?
Any help would be great.
Thanks,
Matt
