Someone Help I Need A Answer So I Can....
Old Feb 9, 2007 | 10:03 PM
CULATR's Avatar
Default Someone Help I Need A Answer So I Can....
so i can.......get this finished on my car, i have a 99 camaro and the tilt on my column theres somethign wrong with it( like something loose or broke ) plus i was wanting radio controls on the steering wheel anyways so i found a few good deal on a columns out of 00-01 a4 cars they sell them complete with or without the steering wheel. they said i could use the existing ignition switch already in the column and not use my original, all i had to do was switch out the body control module that comes with each specific column and they also said the radio controls would work if my car was wired for them ???? My question are they correct about using the ignition key and switch already in the column just switch out my body control module??? next question... is my car already wired for radio control in the wiring harness? if not what do i need to add to make it work properly???? Any help greatly appreciated and thanks ........
