Please help.. problem with guages..???
Old Feb 14, 2007 | 05:49 PM
01Z0H6's Avatar
Default Please help.. problem with guages..???
Recently had my car rebuilt...
Everything is hooked up... grounded etc...
The only guages that work are the fuel,voltage...speedo..
oil press,temp,RPM guages do NOT work...???
Please your ideas..??
Maybe i need to buy a new wiring harness.... as the shop that "did" do my car prior to my current set up may have simply just jerked the harness out..??
Your comments please...
Thanks.
Old Feb 15, 2007 | 05:37 PM
SSmoked2002FL's Avatar
i am having the exact same problem... i believe it is the camshaft positioning sensor... or so thats what i was told... let me know if u find an answer
Old Feb 28, 2007 | 01:00 AM
wazup04's Avatar
me too lol
Old Feb 28, 2007 | 01:16 AM
Duffster's Avatar
cheapest option is to remove your cluster and reinstall to see if something was loose. You use a 7mm socket to get the hidden two screws (for Camaros) or just yank the cover off for Firebirds/TAs. Then using the same 7mm and a socket extension remove 4 7mm screws from the 4 corners of the cluster. You don't have to remove the cluster completely, just loose enough to pull out and reinstall. Reverse the screw installation. I hope this helps!
Duff
