fuel pressure gauge
It has a light with a power & ground pigtail wires. It has another set of wires that goes from the gauge to the sending unit (plugs on both ends) with a power and ground pigtail wire coming from the gauge plug end. I have the light power wire & the gauge power wire connected together and they are connected to a power wire that i already had ran to the fuse box under the hood. I did the same thing with the ground wires.
When i turn the key on, the light works and the gauge pegs the needle. Start the car and the needle stays pegged.
I checked all the wires and none are damaged. Checked and it is getting a good ground and power.
Why does is it pegging the needle?
Only have a "light" wire tester tool. The gauge main power wire gives bright light and the ground is good.
There are 3 wires that go from the sending unit to the gauge. gray (power) black (ground) purple (sends the info). And at the gauge end like i said, it has another power and ground wire to go to fuse box & body ground. The gray wire puts out a dim light on my tester. The black wire is good. Would like to know what how low volts the gray wire is suppose to have.
I have other gauges that are running on the same power wire and they all work.
Thats as far as i've got.
