need a little help
Old Mar 5, 2007 | 10:58 PM
KingdingdongSS's Avatar
Default need a little help
Alright guys iv checked everything but maybe im missing something ...... I'll explain the best i can ..... my amp is on, the connections are correct..... problem is ..... my sub is barely moving its more of a subtle heart beat, instead of actually hitting and making bass...... what could the problem be?!!?! i checked the fuses and all the connections and everything is good ..... please comment back
Old Mar 5, 2007 | 11:09 PM
fredmr39's Avatar
specs on the amp and sub would be nice......provide links if possible
Old Mar 5, 2007 | 11:14 PM
here's the specs..... Panasonic cq-c3333u headunit, JBL GTO coaxials, JBL GTO 1004D 10" sub, JBL GTO CS300.1 300 Watt mono amp ....the sub is 4 ohm, 250W RMS, 1,000 peak..... the amp is self explanitory.
Old Mar 6, 2007 | 10:21 AM
95bat's Avatar
Do you have it hooked up out of phase?
Old Mar 6, 2007 | 02:57 PM
what do you mean out of phase?
it was working fine and then just all of a sudden stopped working
Old Mar 6, 2007 | 03:05 PM
95bat's Avatar
out of phase means the positive and negative wires are reversed. If it was working fine and now you have limited output my first thought would be to check the RCAs.
Old Mar 6, 2007 | 03:24 PM
thosewhohatedmecreat's Avatar
check the gains (duh) try getting a 1/4 inch phono to rca adapter and hook it to a portable cd player/mp3 player and hook it up to the imputs, i have had bad rcas before, it could be a defective unit, make SURE the positive wires go to positive and negative to postitive, hit me up on aim at irresponsibleman and ill help you getin it going
