Hooking up a Nav Unit
Old Mar 16, 2007 | 08:03 PM
LoWeLL216's Avatar
Default Hooking up a Nav Unit
Hi guys,
This is actually a question concerning my wife's vehicle, a 2004 Mitsubishi Endeavor. Since those forums have such limited information I thought I'd post up here.
Here's my situation. I got a Clarion dvd/cd head unit along with a separate Clarion navigation unit. The audio installer hooked up the head unit which works fine. They hooked up the nav unit, but didn't connect it to the speed sense wire (which tells the nav unit how fast the vehicle is going and is required for the unit to track movement) on the PCM. After later tapping the speed sense wire my speedometer went dead and the nav unit still didn't track movement.
The installer is telling me the nav unit is bad and may have fried part of the vehicle's PCM. The vehilce hasn't thrown any codes. I didn't buy the unit from them and because of this they're telling me they are not liable for the "damage" it caused. (I agree with this IF the nav unit did in fact cause the problem)
Question #1 - Does the speed sense wire on the nav unit output any power or is it simply used to read the signal output by the PCM? It seems to me this is no different than connecting a gauge to read an output sigal and highly unlikely that this wire (or the nav unit for that matter) caused this.
I took the vehicle to a dealer to have it diagnosed and they tell me the PCM is fine and that it's most likely from a damaged wire. Basically, the PCM is outputting correctly, but the signal just isn't getting to the speedo anymore. They're not done working on it yet so the story may change, but this is what they think so far.
What I'm thinking is that the nav unit isn't bad, it just wasn't getting a signal (like the speedo) due to a bad speed sense wire tap that damaged the PCM wire. Does this seem reasonable or am I off base here? I do a fair amount of tuning on my Trans Am and have tapped a few PCM wires before to read various information, but have never worked on or installed a nav unit.
Question #2 - I know anything is possible, but is it very likely the nav unit could have done this or is the installer maybe trying to shift a little blame here?
Thanks in advance for everyones help!
Old Mar 18, 2007 | 07:26 PM
JTom's Avatar
the nav just reads off the speed sense. Sounds like they tapped the wrong wire either way for it not to track position. Do you know if they drove it around to calibrate it? I'm not familiar with the kenwoods so i'm not sure how they work.
