Subwoofer noises?????
Old Mar 19, 2007 | 05:25 AM
whitedevil's Avatar
Default Subwoofer noises?????
I am having a weired "cd spinning" and "pulsing" sound emitting from my subwoofer. Even when it is turned all the way down, it still does it. If I turn the gain up, it gets worse. It seems to beat ok, but there is this noise, driving me mad. When I turn the car off, it makes a "thump" and when I turn it on too. Is my amp bad? What could it be? I get motor whine too on some settings.
Old Mar 19, 2007 | 09:36 AM
95bat's Avatar
Sounds like the amp, if I am understanding your description right.
I had an amp do that to me once, too.
Old Mar 19, 2007 | 11:16 AM
MikeFbody's Avatar
Restricted User
could be amp, could be head unit, could be install... hard to tell without troubleshooting and more info.
Old Mar 19, 2007 | 11:35 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I had something very similar, and was able to eliminate it by running my signal and power wires down opposite sides of the car. If you haven't tried that, that would be the cheapest way to look for a fix...if that doesn't work, just work your way down the list.
Old Mar 19, 2007 | 02:59 PM
whitedevil's Avatar
I have heard of the "signal and power" thing before, and to tell you the truth, this is the second amp in the car that did this, so I am hoping that maybe the RCA's went bad, or that I need to run a shielded signal wire, or run them opposite. I will try every thing out. Thanks for the responses.
Old Mar 19, 2007 | 03:12 PM
MikeFbody's Avatar
Restricted User
simply having the rca's too close to your power wire will not cause this. Now, if you happend to put a screw through the rca cable while re-assembling the car, then that will definately do it, as will if the rca ends are broken inside at all.
Old Mar 23, 2007 | 12:17 AM
nomoneyz's Avatar
This exact thing happened in my old wagon. It was the RCA's. I would start by replacing those and see if it helps.
Old Mar 25, 2007 | 07:22 PM
Richiec77's Avatar
Check your ground. Both on the radio side and the Amp side. More then likely it's the amp ground or a ground loop is present.
Old Mar 28, 2007 | 10:25 PM
letsrun97z's Avatar
new rca's fixed that same exact problem
Old Mar 31, 2007 | 05:29 PM
ramairracer's Avatar
does it sound like a heart beat rally loud, mine would do that at low volume, it did that for like amonth but just yesturday the sub busted, the port inside the sub goes bad
Old Apr 1, 2007 | 08:30 AM
I-10 b4c runner's Avatar
sounds like ground looping ... try the grounds 1st ... pull the rca's out just enough so that the sheild disconnects with the outside part to test
The turn-on thump can be cured with a delay circuit ...
This thump is caused by the audio circuitry stabilizing when power is applied. Most amplifiers and source units have muting circuitry that lasts a couple of seconds to allow these fluctuations to subside before passing a signal. However, if the amplifier un-mutes before the source unit or any other accessory
