6.5 Subs to buy
It would be neat to see how they sounded in a TA wired off the stock amp though. I have mine mounted with a baffle (to increase the structural rigidity of the mount) and I also have polyfill stuffed into the speaker cavity to help absorb back waves.
It would be neat to see how they sounded in a TA wired off the stock amp though. I have mine mounted with a baffle (to increase the structural rigidity of the mount) and I also have polyfill stuffed into the speaker cavity to help absorb back waves.About the polyfill though -- do you feel that helped (if so, with what - vibrations?)? I would think it would have a negative effect on sound reproduction since the "cavity" is so large to begin with...
Back of the sub
2" hole drilled, most people do smaller though
Final install, after spacer is installed
where do u get the material t make a spacer or do they sell them premade?
Back of the sub
