switched 12v power
Old Apr 3, 2007 | 09:52 PM
BOTTLEFEDLS1Z's Avatar
Default switched 12v power
Is the yellow wire on the back of the radio, switched 12v power. Its the black 10 pin, c1-9. Thanks
Old Apr 4, 2007 | 07:21 AM
WhiteBird00's Avatar
Ungrounded Moderator
Sort of...it's actually Retained Accessory Power (RAP) rather than straight ignition switched. It remains hot after the ignition is switched off for about 10 minutes or until you open a door - just like the radio.
Old Apr 4, 2007 | 03:51 PM
Ok.
Now what I was gonna do is use that wire to power my sub when the radio is on. Would that be alright?
Old Apr 4, 2007 | 04:04 PM
Originally Posted by BOTTLEFEDLS1Z
Ok.
I assume you mean as the amp turn-on signal not as a power source. If you meant power source then forget it - run a separate power supply wire. If you just want a turn-on signal for the amp there are better choices. On a factory head unit use the power antenna lead (pink wire). On an aftermarket head unit use the supplied turn-on wire - most quality head units have one specifically for that purpose.
Old Apr 5, 2007 | 01:44 PM
Actually, I am wanting to use that wire as a power source for the sub. Right now I have it wired into the fuse panel on the driver side to get power as the key is turned forward, but now Im wanting to use that IGN spot as a switched 12v source for my nitrous plate. I don't have anything in the ACCY spot on the fuse panel either. I looked with a mirror
Any thoughts on where I could get a good, 12v switched power from?
Thanks for the help, also
Old Apr 10, 2007 | 07:19 PM
bump??
Old Apr 11, 2007 | 07:51 PM
ls14thefun's Avatar
orange wire in the ignition harness is the acc power. go to that for a uses and make sure you fuse it
Old Apr 11, 2007 | 11:16 PM
How much more can that wire take as far as amps go??
