Auto door lock bypass
https://ls1tech.com/forums/showpost....97&postcount=1
Would it be safe to say that the original owner decided to do that mod and all he has to do is undo it?
I'm with you - I can't figure out why anyone would want that "feature". If one is that paranoid then just push the lock button. Besides, if the guy trying to carjack you is holding a gun, do you think having the doors locked will help?
I changed the battery because I thought it was dead after sitting for about 3-4 months. I put in a brand new RedTop, but the same issue persists.
Could it be the starter going bad and drawing more current than it should? When I pull off the starter relay and try to crank, the doors don't lock by themselves.
