power antenna to fixed antenna
The antennas do not match perfectly from one to the other. You will most likely need to drill to mount the mast as the TA and Camaro attach at different points on the bracket.
Give BigMike_2005 a shout, he replaced his antenna with a fixed one by getting a std GM antenna off a Camaro. Hell have details on the install but from what I gather it wasnt too hard.
Then you can either get the std GM whip or anyother antenna
you want Then you can either get the std GM whip or anyother antenna
you wantI picked up a fixed antenna bracket from gmpartsdirect for about 20 bucks, you can find it at a dealer for the same price or a salvage yard for cheaper.
radio cable and everything else is the same. I went with bitviper's antenna for mine and if you search the appearance section you'll find my thread with a picture.
quality antenna, same reception, no more broken power units (I lost 2 as well) and looks good
