amp the front speakers ??
Old Apr 23, 2007 | 11:28 PM
homerunhtr21's Avatar
Default amp the front speakers ??
does anybody have a installation guide on on to amp the front door speakers ? I just bought a set of:
Lanzar OPTI62
RMS Power Range : 200 Watts
Peak Power Handling: 400 Watts
Impedance: 4 Ohm
Frequency response: 55-22000 Hz
Design: 2 Way
for the front and was wondering how I would hook it up to a
Sony XM-554ZR
Channel(s)
4 Channel(s)
Output Power
4 x 55W RMS @ 4 Ohm
4 x 65W RMS @ 2 Ohm
1 x 130W RMS @ 4 Ohm - Bridged
Maximum Power
600W .........................................
Please help thanks
Old Apr 23, 2007 | 11:35 PM
99blancoSS's Avatar
bridge both channels and run a sub with the rear unless you bought two sets of speakers and have 4 total. Then just both bridged for the fronts.
You need to decide where you want to put your amp. You need a power supply for it. (12v+ fused from the battery). Your amp should have instructions as well. You'll need to run speaker wire from the amp to the speakers. You need to run cables and a trip wire from the Hu to the amp. You've got a lot of work ahead of you to do it right.
Old Apr 24, 2007 | 09:23 PM
dragonrage's Avatar
Bridge the 4 channels down to 2 channels.
And Sony amps are horrible. Get something better when that one dies.
Old Apr 24, 2007 | 10:05 PM
can somebody tell me what a decent priced amp would be? I have had this one for a while and it seems to do fine, never overheats, nothing but everybody tells me they suck
Old Apr 24, 2007 | 10:24 PM
99blancoSS's Avatar
If it works good for you and your happy then dont listen to what other people say. You can pay anywhere from 50-2000 for an amp. It all depends on your budget and needs.
Old Apr 24, 2007 | 10:27 PM
fredmr39's Avatar
Phoenix Gold.
-depends how much you want to spend and on the amp -- not sure what you mean by "decently priced" -- I assume you meant as cheap as you should buy without sacrificing quality entirely.
Old Apr 24, 2007 | 10:38 PM
99blancoSS's Avatar
Originally Posted by fredmr39
Phoenix Gold.
I'm running a PG Xenon 200.4. Have the rear bridged for the sub. Running Diamond Hex s600's in the doors and a BA G5 for a sub.
