Help on with my system
Old May 1, 2007 | 07:23 AM
199TAmaster's Avatar
Default Help on with my system
Ok guys again I am in need of your help, I have a custom box that fix down in the trunk part it is for 2 10s. I have 2 volfenhag 800watt dual coilovers that im gonna drop in with a 1000watt volfenhag amp. My question are: Does the box need to be ported? How exactly do I hook up a doal coilover sub up? What would look the best covering the box? Finally do I need a power cap?
Thanks In advance.
Old May 1, 2007 | 10:43 AM
dragonrage's Avatar
You mean dual voice coil?
Try checking Volfenhag's site, they might give recommended box configurations.
Old May 1, 2007 | 04:08 PM
I think i figured that one out, now anyone for the other ?s
Old May 1, 2007 | 04:28 PM
dragonrage's Avatar
We need more info on what exactly you have.
And no, you don't need a capacitor.
Old May 1, 2007 | 04:52 PM
fredmr39's Avatar
Originally Posted by 199TAmaster
Ok guys again I am in need of your help, I have a custom box that fix down in the trunk part it is for 2 10s. I have 2 volfenhag 800watt dual coilovers that im gonna drop in with a 1000watt volfenhag amp. My question are: (1)Does the box need to be ported? (2)How exactly do I hook up a doal coilover sub up? (3)What would look the best covering the box? (4)Finally do I need a power cap?
Thanks In advance.
(1) - No (well....I doubt it).
(2) - Voice coils in series or parallel....then subs in series or parallel with one another in the configuration that will give you the final impedance you want.
(3) - That's up to you.......matched carpet always looks best for mobile applications IMO.....unless you're going for some show car fiberglass setup.
(4) - No.
Old May 1, 2007 | 07:39 PM
My biggest thing is the porting I the box Im customizing is ported. Do I need to leave it or close it in?
Old May 1, 2007 | 07:45 PM
fredmr39's Avatar
huh? You don't "need" to do anything -- what do you want?
It sounds like you would be better off sticking to sealed..
Old May 2, 2007 | 08:40 PM
Sorry meant to say that the box I have is already ported should I fill the ports or leave them?
