Amp remote with Monsoon HU?
Old May 8, 2007 | 11:06 PM
JustinID's Avatar
Default Amp remote with Monsoon HU?
Is there a line I can EASILY tap into on the stock head unit (or anywhere really) so I can run a remote line to an amp? I'm replacing my head unit in 2-3 months, but I'm getting impatient having an amp just laying around not getting used. I already have some so-so aftermarket speakers in the doors that the monsoon amp doesn't drive well (at least partly because they are 4 ohm), so that's just motivating me even more.
Ideally, I'd like to not have to cut any wires in the factory harness. I guess if it comes down to it, I'll just use a T-Tap connector on the switched power line going into the HU.
Old May 9, 2007 | 07:10 AM
WhiteBird00's Avatar
Ungrounded Moderator
Use the pink wire that controls the power antenna. It is on whenever the head unit is on - not just when the radio is in use.
Old May 9, 2007 | 08:14 AM
pentavolvo's Avatar
basically what he said... also you can tap in directly at the power antenna in the trunk if thats easier
Old May 9, 2007 | 11:37 AM
JustinID's Avatar
Great, thanks to both of you. I think I'll look into the antenna option first since it's closer and should be easier to access.
Old May 9, 2007 | 11:45 AM
There are three wires at the power antenna - you want the pink one (same as at the head unit).
Old May 9, 2007 | 11:47 AM
JustinID's Avatar
Ok. Thanks again.
