hid fog lights
Old May 8, 2007 | 11:25 PM
540inch Silverado's Avatar
Default hid fog lights
Hey every one I was wondering if anyone else has put HID fog light kits in? I just did mine and they look amazing. I have had one problem a 15amp fuse keeps blowing out? It wipes out my instrument cluster!!!!! I keep putting a new fuse in but that is not the fix! I think i will wire up a wire harness for them. Any comments????????
Thanks Hunter
Old May 9, 2007 | 11:07 AM
SStheBest's Avatar
blowin fuses is never a good sign...sounds like ur groundin out somwhere...try puttin back in the stockers and see if its still happenin...if not then its in ur new setup.
Old May 9, 2007 | 11:26 AM
I know for sure it is my set up.
Old May 9, 2007 | 11:31 AM
LS1_SS's Avatar
You can upgrade the fuse 5-10 amps.
but i was wondering if anyone had wired them on a seperate circut while using the stock swtich.
Old May 9, 2007 | 11:33 AM
that is what i want!!!!
Hunnaaaaaa
Old May 9, 2007 | 01:49 PM
WhiteBird00's Avatar
Ungrounded Moderator
Not generally good advice. In this particular case the circuit is wired with 14-gauge or larger so it can safely handle some additional current (although I wouldn't put a 30-amp fuse in this 20-amp circuit). It is not usually a good idea to put a larger fuse in any circuit. This is especially true if it takes some time for the fuse to blow - any fuse will protect against a dead short but an over-current condition can cause a fire if the fuse is too large.
Old May 9, 2007 | 01:55 PM
Just add a relay, use the original switch and circuit to control the relay, and power it directly from the battery (fused of course).
Old May 10, 2007 | 10:58 AM
LS1_SS's Avatar
HIDs draw less power, only need the initial jolt on stat up, which is probably why his fuse is blowing. Granted I have never had to do it on cars, but every bike requires an 5amp higher fuse for the headlights.
Old May 10, 2007 | 11:06 AM
That could be...in which case a "slow-blow" fuse of the same rating would be safer. The fuse we're talking about is the TAIL LPS fuse so it covers a lot more than just the fog lights. That's why a bigger fuse is a concern. The fog lights may work perfectly with a bigger fuse but if something happened someplace else (say in the wiring to the tail lights), the bigger fuse could prove to be a fire hazard.
