Static In The L7
Old May 24, 2007 | 07:21 PM
jattgunman's Avatar
Default Static In The L7
i recently put my subwoofer back in my camaro and noticed a static when anything using electricity was turned on...i then pulled out my aftermarket deck and shook some wires at the same time the sub would jump......but only when i move my attena plug the sub goes crazy?does anyone know y
(power is away from rca cables)
Old May 24, 2007 | 11:12 PM
jattgunman's Avatar
Someone must know something about this?
Old May 24, 2007 | 11:20 PM
ultraz's Avatar
Start with checking your grounds. IF you can, take pictures of where your amp is grounded.
Old May 25, 2007 | 07:37 AM
wickedwarlock's Avatar
I have to agree, 99% of the problems are poor grounds. If your using a seat belt bolt for the ground, take it off, get out a screwdriver and scrath up the surface under the bolt, works everytime.
Old May 25, 2007 | 11:44 AM
jattgunman's Avatar
Ill take a look at the ground again i did look at it earlier and it was still connected...i did recently hit a curb so im thinking i probally jolted something loose in the deck, but i did find the source of the static and its whenever the attena wire (the round black wire with plug in adapter)is touched or moved
Old May 25, 2007 | 01:31 PM
ultraz's Avatar
sounds like the ground on your radio is bad. Reground the radio to a bare piece of metal with the paint scratched off. The reason an antenna would do ANYTHING would be only if the ground it has, is weak. The radio is grounding out using the antenna.
Old May 25, 2007 | 02:42 PM
jattgunman's Avatar
Thanks guys im gonna open her up again as soon as im off work
