f bodys with underglow
my friend has a 99 t/a red with red neons, looks cool at night, i dont think its ricey at all if you have the HP to back it up, its when you have stock civics with nothing but a fart can and neon is when it gets stupid
Just don't let the tubes hang where you can see them & don't get a cheapo kit.
Just like anything elseBut just to ease your mind... I honestly don't even really ever have them turned on... I forget they are there half the time and it's illegal to drive with them on, and I feel like an attention craving moron if I park with them on
(My tubes are actually on the bottom of the intake, reflecting up, and out...)
I hardly use any of my additional lights, they were all multicoloured used them for a couple of months and for the last 3 years havn't used them at all.
This wasn't my method. I found this website, and followed his example minus some cutting and such.
http://www.paveglio.com/firebird/200...tml#neonlights
If you take the screens off, and look inside, there is a inch or two "shelf" as you will, to set them on. I placed them as far to the front of the hood as I could. Then I drilled holes large enough for wireties to pass through to secure them, and threaded the wires through the holes that were already there. I lined the inside of the intakes with aluminum tape (found at hardware store) for reflectiveness. Ran the wires through the firewall, to a switch where the cigarette lighter used to be, and tapped into a power source. Pretty easy. Hardest part was securing the wires to the underside of the hood so they wouldn't fall into the engine.
Picture of the round switch. Fit perfectly in the cigarette ligher with no modification. Just unhooked the power to the lighter itself so I wouldn't get shocked or pop fuses. Didn't need to use it anymore anyway.
