write up: hi and low beams on same time
98+ have a hallogen system, which is by far superior to the sealed beam system so they made the lows turn off becasuse they would be too bright to be legal.
Projector lows, stock highs and fogs.
Projectors and fogs on:
Highs, projectors and fogs on:
gives you an idea on how much light output is affected.
Anyone else had this problem? maybe if I use a relay instead of a straight jumper?
I checked those and I thought there was a factory one too.Anyways I figured out the highs only stayed on when the fog lights were on, if I turn them off, the highs go off to. So I did the "fog lights on with high beams" and it fixed the problem. Dont know why, dont care but now I have more lights on and they work like they should.
