Power Antenna control
Old Apr 30, 2003 | 01:42 AM
DBLDEUS's Avatar
Default Power Antenna control
If this is an old link could someone point me in the right direction? I heard of some people putting in a switch to control the antenna so it wouldn't be up if I was listening to a cd, just the radio. thanks.
Old Apr 30, 2003 | 08:05 AM
TA TED's Avatar
STF Veteran
Default Re: Power Antenna control
There is a pink wire in pin 8 of the factory radio harness. This wire sends a 12v signal to the internal engage circuit of the power antenna motor. Simply put a small (current draw is only probably 150 mA) switch in line with the pink wire (blu wire on aftermarket head unit). When the switch is closed the antenna operates normally, when you open the switch, the antenna never gets it's 12v and it will stay down.
