Shift light installation
Old May 31, 2007 | 03:57 PM
goodrich969's Avatar
Default Shift light installation
It has red/black/green wires. Red is suppost to go to a 12V ignition switch. Where do I hook up the red wire too, like where on the car. Black goes to a good ground. And Green goes to either negative coil on ignition or to the tach terminal, which I assume is on the PCM. Can someone help me with the red and green wires? Thanks.
Old May 31, 2007 | 07:12 PM
WhiteBird00's Avatar
Ungrounded Moderator
The wonders of search...
https://ls1tech.com/forums/showpost....72&postcount=1
(It's for a Raptor shift light but they all work basically the same.)
Old May 31, 2007 | 09:30 PM
SSNISTR's Avatar
Make sure you set it on 4 cylinder mode.
Old Jun 2, 2007 | 06:56 PM
Why would I set it to 4 cylinder mode?
Old Jun 3, 2007 | 07:46 AM
Well...if you read the post that I linked to...
Because the LS1 PCM generates a two-pulse-per-revolution Engine Speed signal, the Raptor configuration switch needs to be set to four cylinder mode.
