LED bulbs don't work?
. I replaced one with the stock bulb and it didn't blow the fuse, but the blinker then wouldn't work. then i put both the stock ones back in and they work fine. Does anyone know why the LED bulbs make the fuse blow? please help! Also, with the flashers... you'll need to replace the stock thermal flashers with electronic flashers. They can be found at AutoZone for about $8 each, you need two. The part number you need is EL12. LED bulbs don't draw the power that stock bulbs do, and thus can't be controlled by the thermal flashers.
dustin
