Need alternator help
Old Jun 22, 2007 | 04:12 PM
jhanson999's Avatar
Default Need alternator help
I bumped up the alternator in my 2001 LS1 WS6 to a 160amp, and have had charging problems at idle. So, I ordered an ASP Overdrive alternator pulley, and my question is, what belt do I need to get now? I have all stock pulleys except for this ASP overdrive pulley on the alternator.
Thanks for the help!
Old Jun 23, 2007 | 03:26 PM
95bat's Avatar
See if the stock one will fit. Sometimes there is enough slack there, sometimes there isn't I think you can just go to autozone or where ever, tell them what car you have, ask them for a belt 1 size bigger, and see if that fits.
Old Jun 23, 2007 | 04:34 PM
fredmr39's Avatar
wouldn't the OD pulley be smaller?
Old Jun 23, 2007 | 05:40 PM
95bat's Avatar
I thought it was bigger. Hell, I can't remember. Smaller does make sense lol.
Old Jun 23, 2007 | 06:15 PM
fredmr39's Avatar
haha -- yep - smaller since you want to spin at a higher RPM.
Old Jun 24, 2007 | 08:22 AM
Snootch's Avatar
Wouldnt the belt tensioner take up the extra slack from using a smaller pulley?
Old Jun 24, 2007 | 08:42 AM
sunsetta's Avatar
Try the regular belt and see if the tensioner will take up the slack, if NOT, you need to get the parts store to measure yours, and get one 1 1/2" shorter. Trust me, I did alot of research on this for mine, but I have the underdrive crank pulley. I really doubt the spring loaded stock tensioner is going to take up the slack and still have ENOUGH tension to keep the belt on.
Old Jun 24, 2007 | 11:58 AM
95bat's Avatar
Sunsetta can I have your car? Trade you for this pop tart I'm eating?
Old Jun 24, 2007 | 05:30 PM
sunsetta's Avatar
98bat, you don't really want an old wore out 02 with almost 13,700 miles on it.
Old Jun 24, 2007 | 09:31 PM
95bat's Avatar
You're right... plus I already ate the pop tart.
Old Jun 25, 2007 | 08:01 AM
jhanson999's Avatar
Well, it comes in Wednesday, so I'll see if the stock tensioner will eat up the extra. I'm pretty sure the new pulley is smaller, so if it doesn't work, I'll hit autozone and get one 1/2" shorter. Thanks for all the advice guys!
Old Jun 27, 2007 | 10:16 PM
jhanson999's Avatar
Okay, got everything in and working. I spent about 45 minutes tyring to get the damn pulley off with the alternator still on the car. Finally I gave up, pulled it off, and make quick work of it with the impact. Also, for those who may attempt this, the belt to use is Gates model number: K060785. Its 1/2" shorter than the stock belt and fits perfectly.
Old Jun 28, 2007 | 08:39 AM
tonydepo's Avatar
Did that solve your charging issue?
Thanks
