sound barriers
i found that dynamat such materials arent quite as affective as something such as raamat.
but i also read that some people were using a product they found from lowes or any hardware store for that matter with very good results.
i bring that up not for the money issue of it, but i was wondering from some of you that have used that stuff how well it blocked or toned down the exhaust resonance??
or any product for that matter you have had luck with. i am wanting to quieten down the inside of the car. and from what ive read dynamat type materials do that to a certain degree, but if im wanting to queten the exhaust it might not get the job done.
It works fine on like the floors and truck....may have to double up some places its not near as thick as regular car audio sound deadner
As that test showed...cant go wrong with SecondSkin...may be a lil bit more pricey than some but its worth it
Or if u wanna go a slightly diff route:
http://www.secondskinaudio.com/viewp...92&category=50
Something like this would be a lot easier to spread into areas you cant put down a strip of deadner...but good luck with ur decision
I don't know if I would go with Peel and Seal. It had a funny smell at the local Lowe's here in Houston. Maybe because the actual store was hot, but I can only imagine what it would smell like in my car.
can you imagine using the cheap stuff, and having it melt all over your carpet? or having it slide off the firewall/doors/headliner/etc., and having to go back and first try to clean up the old mess, then buy more damping mat, then reapply the new stuff? it would simply be cheaper in this scenario to pay a bit more for the good stuff up front and just have to mess with it once.
not to mention, from what i've heard, the asphalt-based stuff (especially Peel-N-Seal) tends to stink up the car pretty badly when it gets hot....i don't know about you, but i don't want my car to smell like ****....cause that's roughly what asphalt smells like.
sound deadening will likely be my next project, and i will likely end up using the Second Skin stuff, and get it done right the first time
*edit* almost forgot to mention, their barriers are good, but their dampener products are crap! Don't be tempted. It's a vinyl sheet that may be suited for home apps, but will dry up & flake off in cars.
made a very noticeable difference
If money wasn't an issue I would go with Damplifier Pro and Over Kill Pro, which would be about $1100 versus $600 for the RAAMmat and Over Kill.
