Dillema...what Subs To Go With???
the difference with 10w3v3-2 ohms, 10w3v3-4 ohms, 10w3v3-8 ohms
whats the best way to go? each sub has a 300 watt rms (continuous)
help!!!
So, we really need to know what amp you are going to use to let you know what subs to get.
With that being said, you'll do well with having either the 10w3v3-4 ohms or 10w3v3-8 ohms. Wired in parallel the 2 4ohm subs would yield 2 ohms. The 2 8ohm subs would yield 4 ohms. I would choose the 2 4 ohm subs though. It would be easier to sell the subs independently when you do.
Dual subs
Dual Voice Coil
2 ohms = .5 ohm load
2 ohms = 2 ohm load
2 ohms = 8 ohm load
3 ohms = .75 ohm load
3 ohms = 3 ohm load
4 ohms = 1 ohm load
4 ohms = 4 ohm load
6 ohms = 1.5 ohm load
6 ohms = 6 ohm load
8 ohms = 2 ohm load
8 ohms = 8 ohm load
I can get you wiring diagrams for any of those also.
