HUD for an f-body???
Old Aug 8, 2007 | 11:36 PM
DVS99TRANS's Avatar
Default HUD for an f-body???
Has anyone ever seen or heard of anyone carrying it??? I know the vette runs off the same basic PCM and don't see why it couldn't be done. The only thing I don't know is if the HUD runs off the PCM or the console itself???Easiest case scenerio jumping/splicing a couple wires and fabricating if into the front dash. It is a kind of pointless mod and doesn't make you perform any better but would be very unique I think and wouldn't mind doing it. Any one know???
Old Aug 9, 2007 | 08:42 AM
pentavolvo's Avatar
In the vette it runs off the gauge cluster
Old Aug 9, 2007 | 08:50 AM
Jon5212's Avatar
+1 I think that would be pretty cool too, not sure of the cost to do that though.
Old Aug 9, 2007 | 12:13 PM
DVS99TRANS's Avatar
So atleast you wouldn't have to mess with the PCM it sounds since it goes of the gauge cluster. I'm half thinking about buying the HUD and giving it a try. Just need to find a wire diagram for a vette to see exactly what wires it will tap in to. I'm just not that crazy about ripping/cutting a hole in the dash I work on aircraft avionics splicing and soldering stuff all the time. I can't see it being anywhere worse than that.
Old Aug 9, 2007 | 12:29 PM
Shockwave179's Avatar
If you can't get the corvette setup to work, Defi makes HUD units..
Old Aug 9, 2007 | 07:51 PM
VIP1's Avatar
Copy & Paste Moderator
Here is an older thread on HUDs:
https://ls1tech.com/forums/appearance-detailing/689186-c6-hud-fbody.html
Old Aug 10, 2007 | 01:04 AM
DVS99TRANS's Avatar
That may be, but I'm also trying to find what wires that the HUD runs off. I have EVERY RESOURCE on wiring at my disposal. I work in an avionics shop for HC-130s, me installing it isn't the question. It's finding what inputs the HUD needs??? It will of course need power and ground, but what other inputs that an f-body might not have that a vette will. I mean I could always pay an arm and a leg and buy it from GM directly and jump it from the console. Kind of a very technical question. Not trying to be rude, just looking for a little more than what I've found.
