Best ground?
If you just need to test the amp, you could try running a long ground wire all the way out to the battery (NOT a permanent solution, just for testing). If the system works while it's tied straight to the battery, then you'll know it's a ground issue. If it still has problems, you'll have to check other possibilities.
sorry i also forgot to mention to sand it down like brian2006 said
