backseat pics & kicks
http://photos.yahoo.com/bc/richieg26...tos.yahoo.com/
p.s. would somebody tell me why I can't get pics to come up with my posts? everytime I try, it just shows the web address. tia.
[image]http://us.f1.yahoofs.com/users/2f015ea0/bc/Cars/Install/offwiththecover.jpg?bcQuA3.A1nU2TBDN[/image]
But it obviously didn't work, does yahoo not allow direct linking maybe? I also tried [img] tag as well...
I've got a few questions if you don't mind?
For installing the Focals in the kicks, what kind of problems did you run into? I can't imagine the install on the drivers side was very easy. Also, what did you mount the speaker to?
For the 8"s in the doors, what kind of modifications did that take to make them fit? And did your door panels clear the speaker, even with the max cone excursion? If so, what kind of modifications did it take to fit them in there?
Great work on the amp rack too, but I don't think I'm going to tackle that one.
The eights were just trial and error as far as where to place them to clear the window. I had some 8" trim rings from a set of kicker eights that were a little bit larger than the quart 8" I placed them on the front of the quarts to keep the door panel off of the speaker during high excursion. The fibercore doors are real easy to trim, I used a razor blade to cut them. (not the strongest stuff). I cut away a large section of the door, made a 1/4 trim ring and countersunk some bolts, than screwed the speake into the trim ring. The trick is to keep the speaker as low & as far to the hinge as possible to clear the window. There is more pressure against the door panel, but it still fits fine. Later down the road, I'll build a new lower door panel and give those eights a little enclosure.
One last question, which model MB's were those 8's that you put in? I'm wondering if something like a DEI or a Kicker RMB would fit easier.
They use inverted magnets, so the window shouldn't be as much of an issue.
