Weird Headlight Problem
Old Sep 8, 2007 | 09:16 PM
FBDYLVR's Avatar
Default Weird Headlight Problem
My T/A has a weird headlight issue going on. Both low beam bulbs are good, but only the driver side lights up. When I turn the switch on, there is 12V at the connector with the headlight unplugged. The second I plug a headlight into the connector, the voltage drops to 0. This problem is really confusing me. Any help would be appreciated.
Old Sep 8, 2007 | 09:33 PM
SparkyJJO's Avatar
Sounds like it is grounding out. But it does this with either bulb?
Old Sep 8, 2007 | 09:39 PM
FBDYLVR's Avatar
Yes, I took the bulb from the driver side and tried it on the pass side and thats what happens.
Old Sep 8, 2007 | 09:50 PM
SparkyJJO's Avatar
Is the socket OK? Check your ground connection as well.
Old Sep 8, 2007 | 10:13 PM
FBDYLVR's Avatar
I guess there's a flaky connection in the weatherpak connector. I plugged and unplugged it, and it worked fine.
Old Sep 8, 2007 | 10:15 PM
SparkyJJO's Avatar
OK glad you found the problem. Keep an eye on it, you may need to replace it but maybe it was just loose and will be fine.
