Installed Raptor Shift light, got a question
Old Sep 27, 2007 | 11:09 PM
wssexorz's Avatar
Default Installed Raptor Shift light, got a question
it was a pretty easy install, I hardwired my V1 at the same time ... but whats goin on is if i have it set at say 5300, when i'm in 1st at WOT it seems to go off at like 4k ... if i go slow through 1st it won't go off till 5300 like it is set to ... what would cause this?
here is the install pic of where i put it
Old Sep 27, 2007 | 11:16 PM
pentavolvo's Avatar
thats cause the stock tach is slow, and in 1st you rev faster then the tach can spin
Old Sep 28, 2007 | 12:17 AM
kbronSS's Avatar
no ****??? so if your looking at your stock tach and shifting at 5300 like he says, then around what rpm is he really at??
Old Sep 30, 2007 | 02:27 AM
pit's Avatar
pit
do you have it set right? i needs to be set to the 4 banger seting or else it will not work. shoot me a pm if you have any questions
Old Sep 30, 2007 | 03:45 AM
Snowman2K1's Avatar
im ready to order my raptor..just want to make sure its the right one and also easy to install..im also going to put it in the same place
Old Sep 30, 2007 | 04:41 AM
2MuchRiceMakesMeSick's Avatar
which wire did you use to get the rpm reading? (hopefully the pcm)
are you sure your not spinning the tires? (is it all gears or just first?)
did you take the grounds to BARE metal (very important)
