Why is the TCS switch wired to the headlight motors?
Old Jun 12, 2003 | 02:15 AM
waxzx's Avatar
Default Why is the TCS switch wired to the headlight motors?
Well I'm not a GM guy, but I helped my Friend install a big 5" Tach with a shiftlight (which I think is damn useful)in to his 2001 Trans Am. I've already mentioned how I’m not a GM guy so when I thought about where to connect the power and light (power when the lights are on) I saw the TCS switch I thought that should be easy. It lights up when the lights are on and I should be able to find a 12volt source there. Well I found what I was looking for and started to wire it up. I try not to make mistakes so I double checked my wires. I hook up the volt meter and when I connect the power for the interior lights to the ground the headlights pop up. Now I’m not a GM engineer but why exactly are the headlights even remotely connected to the TCS switch? I finally got everything sorted out, but I’m really confused. Yalls cars kick *** but damn you have a weird electrical system.
