Map lights wont turn off
Old Nov 28, 2007 | 12:21 PM
Sprayin01Z's Avatar
Default Map lights wont turn off
Had the car sitting for a while. Battery died. Went to jump it. Battery was no good. Replaced battery. Now the map lights wont turn off. Any idea what it could be? I pulled the fuse to get them to turn off for now. Also the radio, cluster, and who knows what else is fried. Any help would be greatly appreciated.
Old Nov 28, 2007 | 01:49 PM
SparkyJJO's Avatar
sure your switches aren't turned on?
Check to be sure your doors and hatch are all closed fully. If they are then you could have a bad door switch someplace.
Old Nov 28, 2007 | 03:31 PM
Sprayin01Z's Avatar
Switch is off. All doors are closed. Ill look into the door switch. Anything else someone may want to add would be appreciated.
Old Nov 28, 2007 | 05:44 PM
camaro-94-z28's Avatar
sounds like u have the dial all the way up. otherwise i have no idea
Old Nov 28, 2007 | 06:03 PM
Sprayin01Z's Avatar
Nope. Its off. The lights just wont turn off. They remain on until either battery is dead or I unplug the fuse. Anyone else?
